АвторТема: не дайт изменить/посмотреть свой профайл а так же профайлы других участников.  (Прочитано 7211 раз)
drovosek
Выкидывает следующую ошибку кода :
An error occurred during the on-the-fly user creation
Error (ERROR_BAD_PARAMETER)
in D:\wwwroot\velik.org\gallery2\modules\core\classes\helpers\GalleryPermissionHelper_advanced.class at line 198 (GalleryCoreApi::error)
in D:\wwwroot\velik.org\gallery2\modules\core\classes\helpers\GalleryPermissionHelper_advanced.class at line 131 (GalleryPermissionHelper_advanced::_changePermission)
in D:\wwwroot\velik.org\gallery2\modules\core\classes\GalleryCoreApi.class at line 823 (GalleryPermissionHelper_advanced::removeUserPermission)
in D:\wwwroot\velik.org\gallery2\modules\useralbum\classes\UserAlbumHelper.class at line 87 (GalleryCoreApi::removeUserPermission)
in D:\wwwroot\velik.org\gallery2\modules\useralbum\module.inc at line 154 (UserAlbumHelper::createUserAlbum)
in D:\wwwroot\velik.org\gallery2\modules\core\classes\helpers\GalleryEventHelper_simple.class at line 59 (UserAlbumModule::handleEvent)
in D:\wwwroot\velik.org\gallery2\modules\core\classes\GalleryCoreApi.class at line 2238 (GalleryEventHelper_simple::postEvent)
in D:\wwwroot\velik.org\gallery2\modules\core\classes\GalleryEntity.class at line 285 (GalleryCoreApi::postEvent)
in D:\wwwroot\velik.org\gallery2\modules\core\classes\GalleryUser.class at line 218 (GalleryEntity::save)
in D:\wwwroot\velik.org\gallery2\modules\core\classes\GalleryEmbed.class at line 408 (GalleryUser::save)
in D:\wwwroot\velik.org\components\com_gallery2\classes\user.class at line 41 (GalleryEmbed::createUser)
in D:\wwwroot\velik.org\components\com_gallery2\classes\core.class at line 219 (user::newUser)
in D:\wwwroot\velik.org\components\com_gallery2\classes\core.class at line 159 (core::init)
in D:\wwwroot\velik.org\components\com_comprofiler\plugin\user\plug_g2bridge\g2bridge.php at line 41 (core::initiatedG2)
in ??? at line 0 (getg2bridgeTab::getDisplayTab)
in D:\wwwroot\velik.org\administrator\components\com_comprofiler\plugin.class.php at line 265
in D:\wwwroot\velik.org\administrator\components\com_comprofiler\comprofiler.class.php at line 3928 (cbPluginHandler::call)
in D:\wwwroot\velik.org\administrator\components\com_comprofiler\comprofiler.class.php at line 3736 (cbTabs::_callTabPlugin)
in D:\wwwroot\velik.org\components\com_comprofiler\comprofiler.html.php at line 391 (cbTabs::getViewTabs)
in D:\wwwroot\velik.org\components\com_comprofiler\comprofiler.php at line 468 (HTML_comprofiler::userProfile)
in D:\wwwroot\velik.org\components\com_comprofiler\comprofiler.php at line 80
in D:\wwwroot\velik.org\index.php at line 264
а поточнее можно с какого броузера где что как у меня пока с телепатией не очень хорошо
drovosek
с хрома ,фокса и ехплорера одинаковая ошибка ,которая не имеет отношение к браузеру поэтому телепатом быть не надо.
Судя по ошибке проблема из за пермишенс ,видимо юзер плохо создался.
странно не у кого вроде пока такой проблеммы не было и я щас без проблем захожу на твой профиль
 если под аватаркой своей на форуме ты клацаешь на просмотр профиля что происходит ?
Оффлайн Voronin
  • Капитан
У меня тоже самое на всех браузерах, суппорт молчит на письма...
Кто рано встает,Тот всех достает!
Оффлайн Repkin
  • Ninerd
у меня работает (мозила)
Помечен как лучший ответ пользователем 22 Ноября 2024, 13:55:36
Оффлайн Voronin
  • Капитан
drovosek
Это не только мой профайл,я и чужие не могу видеть ,вылетает та же ошибка .. .
Может стоит удалить мою юзер и я создам заного ? удалить должен админ с базы данных что бы я ник не менял.
drovosek
Перезвони мне . попробуем решить на месте
drovosek
может попробуем удалить и создать профайл заного ? у меня ошибка не прошла хотя у других вроде уже ок ...
Как вариант залогинься с моим пользователем и увидишь эту ошибку.
Напиши мне номер телефона я скину смс с паролем.
Andy
Присоединяюсь к данной проблеме. Тоже самое...
Захотел поменять профиль, изменить аватарку, а где там  ???
Оффлайн Drovosek
Andy
Попробуй изменить профиль  должно уже заработать .
Оффлайн Drovosek
Думая Алеху надо будет добавить таблицы в БД которых не хватает для юзера.
Так он решил мою проблемму.
